It is currently Thu Aug 21, 2025 11:03 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 21, 2022 2:27 pm
First name: Roger
Last Name: Häggström
City: Örnsköldsvik
Zip/Postal Code: 89136
Country: Sweden
I can't prove anything about the tone of a guitar, but I could clearly hear the difference with and without the PlateMate. Very metallic tone with it and not so without it. I don't think a PlateMate adds a significant weight to the system, I don't have one to weigh (for obvious reasons!), so I don't actually know how heavy it is.
The weight of the bridge/pins/plate is of course very important, but I think it's wrong to explain any change in tone in a guitar with weights alone, it's too easy. I believe different hardness and materials also have an important role when it comes to tone.
New will change the old,
turn to ashes or gold
http://www.gammelgura.se
PostPosted: Fri Apr 22, 2022 3:51 am
No problem believe what you wish. A change in mass over the bridge area of an acoustic guitar (weight...) has long been accepted by many Luthiers as a tone altering, possibly event. It's why we explain the difference that some people perceive with different bridge pins and materials.
The bridge plate and any cap or saver is not part of the speaking length of the string and as such it's impact on tone is likely in my view non-existent.
PostPosted: Fri Apr 22, 2022 5:38 am
First name: Roger
City: Örnsköldsvik
Country: Sweden
What I believe is based on many, many practical experiments. One of them changed the tone dramatically just turning the same spruce wood in the end grain direction (spruce is about 3 times harder in that direction) compared with the usual radial/tangential direction. No change in weight, big change in tone.
PostPosted: Fri Apr 22, 2022 3:57 pm
If any has a chance they should really read Rogers article in American Lutherie.
PostPosted: Fri Apr 22, 2022 5:21 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
Jim, seems like you really liked it. Which one was that? Roger wrote quite a few.
Pierre
Guitares Torvisse
Pierre Castonguay
PostPosted: Fri Apr 22, 2022 9:45 pm
It was the winter issue, #144. I'm just plugging it (pun intended :) ) as it's totally relevant to this discussion on plugging bridge patches. It's obvious he put a lot of work into it and he presents some data on various plugs. I don't necessarily see myself following this path at this point in time as I try not to do too many repairs. But I do think if someone was interested in plugging a bridge patch, it'd be some food for thought.
PostPosted: Sat Apr 23, 2022 8:16 am
First name: Pierre
City: Québec, Qc
Thanks!
Pierre
Guitares Torvisse
Pierre Castonguay
PostPosted: Sat Apr 23, 2022 6:00 pm
First name: Matt
Last Name: D
Hesh wrote:
Caps are a great answer especially for the crowd that does not want metal in their guitar and thinks that there may be a tonal impact (there isn't but they think that anyway....). A cap can be banged out in three minutes .055" thick, good ole Michigan rock maple and no need to purchase anything from anyone. In either case consideration for possible pick-up interference in installation should be considered as well.
But the best solution is a slotless pin conversion cap or saver and refitting the instrument for slotless pins. We have restored 1870's Martins with slotless pins and there was zero bridge plate wear.
Bridge plate wear on modern steel strings is actually a fairly newer thing and resulting from some genius at a f*ctory determining that if they used mass produced, cheap plastic bridge pins with slots in them they would not have to pay semi-skilled labor to slot the bridge, top and plate for slotless pins as it was in the past.
But what no one cared about or knew is the slot in the pin and to a lesser degree the taper at 5 degrees permits the string balls to eat away at the edges of the pin holes and that's what results over time in bridge plate wear. Unslot the pins and properly fit the instrument for this and there is no bridge plate wear. 3 degree pins do better too, unslotted in keeping the string balls from the edges of the string holes.
My business partner David Colling presented a talk on this subject at one of the Northwoods seminars and he called it the "Deevolution of the Bridge Pin." Many of you who have come to classes at our place may remember the posters on the wall describing this.
Fascinating. Never heard of this before. Am definitely going to look into this and might start taking this up as standard practice. Great bit of information!
